so i have an h440 case and i was wondering if i have a 280mm kraken x61 radiator as an intake on the front of my case (for my cpu) and then have the nzxt g10 bracket for my gpu and then put a kraken x40 on that and use that radiaotr as a rear exhaust. would i still need my 3 top case fans since the big radiaotor is cooling my cpu and bringing air in while the smaller 140mm radiator for my gpu is exhausting out the back. the point of this is im trying to make my case quieter and by taking out the top 3 case fans io have installed and just using the radiators, i think it would make it much more quiet. The problem is will my mobo/ram and other components heat up if i dont have top case fans????
