Case cooling feedback.
Liracto
44
Hi, I’m looking to modify my case to improve cooling and noise efficiency. Due to its rare trait of having a window on the opposite side to conventional cases I have a Thermaltake core G3.
I have ordered the fans needed to complete the plan shown below and will be making modifications to accommodate them as shown.
Any feedback or advice would be greatly appreciated.
Specs-
GPU: MSI GTX 1070 Quick silver
CPU: AMD FX8350
AIO: Corsair H80i v2
SSD: Samsung 850 Evo pro
HDD: Seagate 3TB
Motherboard: Sabertooth 990FX R2
PSU: Corsair SF600
If you're going to be using the PSU to help exhaust I recommend having it up on table or off the ground that is. also keep in mind that if you're going to be using the PSU to exhaust you need to have a good filter underneath cause dust will go and clog the airflow so less air exhausting.
