Hi All,
Im hoping someone can help with my case cooling, Things are starting to run a little warm of late - nothing dangerous but cooling could do with being increased.. Im not great with the technicals so here goes..
My current setup uses (http://uk.pcpartpicker.com/list/DkhYHN)
2 x Corsair CO-9050016-RLED 52.2 CFM 120mm Fan These are mounted at the front and are the EXHAUST
1 x Corsair CO-9050016-RLED 52.2 CFM 120mm Fan This is mounted at the top for an intake
1 x Corsair H80i GT 70.7 CFM Liquid CPU Cooler This is mounted on the rear of the case and is the INTAKE powered from CPU_FAN2 and SATA Power Cable to Pump Head
This is the only way i can set it up as the radiator can only fit/reach being mounted where it is.. Picture attached..
My motherboard fan connector config is
• 2 x CPU Fan Connectors (1 x 4-pin, 1 x 3-pin)
• 3 x Chassis Fan Connectors (1 x 4-pin, 2 x 3-pin)
A couple of questions to close
All of my fans are 3pin, I was hoping there was a way I could control the speed of the Corsair fans to ramp them up?
Will the 3 Pin Corsair fans be running at full speed all the time?
If i added a speed controller Would I be able to control the RPM?
Currently, the available power connectors with FAN written on them are
PWR_FAN1
CPU_FAN1
PWR_FAN1
CPU_FAN1
