Case Cooling Solution
JGunnzz
61
I just built my very first computer, I'm using a cooler master n200 case with an AMD fx 6300 CPU and an EVGA GTX 750ti superclocked edition. At the moment I'm using the stock fans for everything. I know that these components may not need a whole lot of cooling but it gets very hot where i am in the summer, and I don't have air conditioning. I was wondering if someone could recommend some good case fans and a good CPU cooler that will fit in my case. I was looking at the Cooler Master hyper 212 evo nfor the CPU. I'd rather them not be crazy expensive. For the case fan I will powering them by molex so keep that in mind. Thanks in advance.
Cooler Master hyper 212 EVO is one of the best air coolers. You need to decide if it will fit inside your case and clear your memory sticks.
Cooler Master's website says that that case can support CPU coolers as tall as 160mm or 6.3 inches. I'm not sure how tall the hyper 212 EVO is.
