Anyone got any opinions on cutting a hole out of front base of a case for an intake fan?
Presumably the case will need to be on legs for adequate air supply and noise prevention.
Any concerns about weakening the case (aluminium) or angle of the fan?
On a different thought, wondering whether creating guides inside the case would be beneficial, giving the air a set path...
Obviously be problems getting around drive bay etc, but if you used a flexible enough material, you could take into account HS and drives?
So basically imagine a your case as a box with an "S" inside with the front of your case to the left.
Suck air in the bottom front, past, gpu, them cpu the drives and out the psu?
Or even "different" air for different components,
gpu, cpu, drives + psu?
Like a case divided into 3 horizontal sections
(A square with an E inside )
intake at front and blowout fan at rear for each section?
just use a free drive bay for the top intakes?
Anywho, feel free to poke holes in, and fun at my ideas! (",)
