Hi. I'm running an Athlon 1.2 (not o/c'ed). If I close the case and run a full load, the CPU temp can reach about 70C, usually crashing the system. In the meantime, I've decided to leave the side of the case open, and set my huge 18" room fan on its side, blowing straight into the case. That of course improves airflow tremendously, such that the CPU temp never goes much over 50C, even while running a full load.
My question is, what kind of setup would I need to achieve this same cooling with the case closed, using intake and outtake fans? Also, where should the intake/outtake fans be attached within the case for the best results?
I'm trying to decide if it's actually worth doing something like that, or whether I should just buy a smaller room fan and just set it on the floor, blowing directly into my case, as my large room fan is doing now.
Thanks,
xdarque
Thanks,
xdarque
