Case Cord Plugs to Mobo Help
Dannynub
7
So I am a newby pc builder and i manged to build my current pc all okay without anyproblems. But since the first build i have neglected the +5v, D+, D-, Ground cable from my case and i guess that cable is for the front panel sound and usbs but im not sure where to plug them in. I have referred to the manual many times but i never got it.
Thermaltake Commander Mid tower atx
ASUS P8Z77-V LK
Usually the ports on the board are marked. Look at the board for nine-pin headers that look like the pic and it should say "USB" above or below that header. It doesn't matter which USB header you use. In the mobo manual there should also be a diagram showing the location of different ports and headers. Any one that's marked USB 2.0 will work.
