Case - Corsair SPEC-01 RED ATX Mid Tower Case - False Advertising
justinf10000
Commendable
Feb 25, 2016
209
Link to the case
Have to say i'm a little bit dissappointed.
This case is advertised in its specs as having room for 2 front 120 or 140mm fans.
The 120mm fans fit fine, but I bought a 140 mm fan and it doesn't fit at all. This is the fan I bought. NZXT Technologies NZXT FZ-140mm Red LED Cooling Fan.
Right now its working (its wedged between the front panel and the case, but this is not optimal).
So why doesn't it fit?
1. The screws that come with the fan are way too big to fit into the 140mm spaced holes on the case.
2. The 140mm spaced holes on the case are not even accessible.. no screw would fit there. The holes are actually halfway blocked by the metal bracket (part of the case) that is used to support DVD/etc drives. Like what the hell? There's no way to remove that bracket either.
Why did they build the case in this way but advertise it as saying 140mm fans can fit on the front? They clearly can't. I'm going to keep the 140mm wedged in like it is (surprisingly its not making any rattling or anything, but its still not secure), but it's lame it can't be screwed in.
Did I do something wrong or is this a design flaw?
G
You should check the manual and/or contact Corsair. That doesn't make any sense. Perhaps they didn't drill the holes in the right spots?
Newegg got the specs wrong. I would blame Newegg, but not Corsair.
From the Corsair website it says, Front: (x2) 120/140mm
Since the (x2) is not in front of the 140mm, I would assume that's for two 120mm fans or just one 140mm only.
I only have 1 140mm and 1 120mm. The 140mm doesnt fit in either spot (top or bottom).
I did that. I tried fitting it in the top and the bottom slot. The holes are blocked on both locations.
This picture doesn't show if its actually screwed in or not.. so it might just be sitting there just like mine is.
Either that or I have a defective case? I dont know.
Yeah i think you might be right.
So the next question is, is it worth it RMAing a case so i can have 140mm fans mounted instead of 120mm?
I think not... but it still sucks it was released this way. Thanks for the opinion tho, i just wanted some input.
I wouldn't assume that at all. I would assume they meant two of either or one of each. If it is indeed misrepresented or defective then I think Corsair should send you a complementary 120mm fan and I would let them know that.
