Case decals Air 540 window
kye1987
42
Hi
I wanted to know if anyone had a clue where I could get a decal made up for my Pc case window. I was hoping for a mix of different gaming characters along the left side of the window. Perhaps Mario, pokemon, final fantasy that kind of thing.
I've looked around and found on eBay there are single stickers of these characters, so i could make it look decent. But not as good as 1 solid decal
You can often find print shops nearby (in the US: staples, officemax, fedex in some cases) that will print on vinyl material which can be applied and removed very easily. I'm sure there are online options for this as well. If you can make the image of what you want, you can usually email the file or take it to a local shop on a jump drive, disk or cd/dvd and specify the print size.
I've done this for regular window graphics, the vinyl adheres very smoothly if you apply it in a linear fashion from end to end and then removal leaves nothing behind that some glass cleaner cant remove.
