Case design (fans)
zZoKo
60
Hi, im building a pc with a i7 7700k and 1080 in 2 weeks for black friday, im going for a black and green setup, the case that im using is s340 razer edition, link:
https://www.komplett.no/product/855757/datautstyr/pc-komponenter/kabinetterbarebone/midi-tower/nzxt-s340-special-edition-tower?offerId=KOMPLETT-310-855757#
and the case has 1 stock fan in the back and another one in the top, and 2 more fans can be added in front (120mm-140mm) the fans in the front cant really be seen when the panel is on from what i heard, so i was wondering whether it would be a good idea to take the fans from the back and top and put them both in front, and in the back and top use 2 corsair air sp120 led green, link:
https://www.komplett.no/product/837882/datautstyr/pc-komponenter/casemods/vifter/corsair-air-sp120-led-groenn-120mm-vifte?offerId=KOMPLETT-310-837882#
TD:LR can i move the fans from the back and top in front and use 2 corsair air sp120 green fans? (front fans cant be seen so no point to buy led fans there)
also should i go for be quiet silent wings 3 instead with no leds? would it be quieter?
whole setup: https://www.komplett.no/wishlist/shared/38fd4735-9719-484c-9c7b-9f01123e71fe
edit: i switched to 1080 strix instead of armor
i might have explained bad but what im trying to say is if i can take the 2 stock fans from top and back and mount them in front where they cant be seen, and then i take the other 2 fans with fancy light bought on market and put those on the back and top where the light can be seen, basically if i can move the ugly back fans in front and install new fancy one in the back
found out that the case comes with 3 pin connectors for fans which i dont want so ill just buy x4 be quiet pure wings 2 and replace everything, thanks for help anyway
