Case dilemma/problem
arubberduck
Hello all
I have a build (which will be my first) that I am happy with, but the case is kind of causing me problems. I want a NZXT Phantom 410 but I don't know if it is an adequate size for all of my components so the dilemma is go for the mid tower which might restrict cooling and might not even house the components well or go for the bigger more expensive full tower Phantom which will have good cooling and be spacious enough for upgrades but could cause minor problems with placement. Could someone please offer their opinion, also could you please tell me if my power supply is adequate as well for all of the tasks I might also add things into the 5.25 bays like a NZXT Aperture M (when it gets to the UK, if it does) or maybe even a NZXT Bunker (because I am getting a wired keyboard and a wired mouse). Feel free to rate the build I'm mainly going to be using it for gaming. Also I might crossfire the video card later when it starts to run out of puff.
Thanks to anyone who contributes
Alex
Here's my build (Not finalised)
CPU: Intel Core i5-3570K (Stock 3.4 Ghz)
CPU Cooler: Cooler Master Hyper 212 EVO Sleeve Bearing CPU Cooler
Motherboard: Asus SABERTOOTH Z77
RAM/Memory: Samsung 8GB (2 x 4GB) DDR3-1600
Storage 1: Western Digital Scorpio Blue 750GB 2.5" 5400RPM Internal Hard Drive
Storage 2: Kingston SSDNow V200 Series 128GB 2.5" Solid State Disk
Video Card: XFX Radeon HD 6950 2GB Video Card
Aforementioned Case: NZXT Phantom 410 (White) ATX Mid Tower Case
Power Supply: NZXT 750W ATX12V / EPS12V Power Supply
Optical Drive: Sony BD-5750H Blu-Ray/DVD/CD Writer
Again thanks to anyone that helps.
Similar threads
