Hi. I recently purchased new case fans for my system and I am struggling to find software/fan controller to manually adjust custom fan curves. Fixing it in the BIOS won't work because it forces the fans (even in custom) to run at 100% ofter the CPU runs at 75 degrees plus. Ideally, I want the fans to ramp up to 75% at 80 degrees and 100% at 90 degrees plus. I have tried multiple different types of software but none seems to work. Currently, I have the H150i pro AIO cooler from corsair which has its own temp for the coolant. I was also wondering if I can just sync my case fans to the corsair fans in Corsair link. If software is not the option, what fan controller/hub can I use to control the speeds of my case fans manually. My case fans are 4 pin fans.
Thanks in advance.
Thanks in advance.
