Case fan extentions
ZitchXx
16
I only have one free 3 pin fan port on my motherboard, if I get this cable and plug 3 fans into it will all the fans run at full power or will the power be split up between the fans?
The first blue link will be fine. The second link is dead.
IF you buy that the fans will run at max speed and you will not have control over them.
Oh right :') bad idea then, what about using something like this or this?
