Is there any fan performance lost if you were to place the fan filter on the intake side of the fan, as opposed to the output side?
My set up currently is this:
FAN >>AIR FLOW>> - CASE
My case setup (Rosewill Challenger) prevents me from easily accessing a front fan filter between my fan and case, and would like to have it set up like:
FAN FILTER - FAN >>AIR FLOW>> - CASE
What Ive seen, most setups are:
FAN >>AIR FLOW>> - FILTER - CASE
Does it really matter where you place the fan filter? My top and top rear 120mm fans blow out, while my 2 120mm side fans, and front 120mm fan blow inward. My 92mm CPU Cooler fan blows upward towards my top fan, essentially blowing out.
Currently the only fan filter I have is the one that came with the case, at the bottom for the PSU, which allows easy access to clean it out, and I do get a decent amount of dust still in my case, and want to eliminate as much of it as possible. I still want to be able to access the fan filters so I can clean them at least once a month, without having to uninstall my fans, as I plan on using rubber grommets to reduce vibration noise, and dont want to cause undue wear and tear on them.
Currently using 2xAPEVIA CF12S-BK 120mm, 1xAntec TrueQuiet 120mm and 1x120mm Rosewill that came with the case, if that makes any difference in filter placement.
Any help is greatly appreciated!
