[SOLVED] case fan for Meshify 2xl
LeVzi
147
4
18,585
By default the case has two front panel fans 280mm (2 x140mm) there's space for one more , and id like to add another fan like what's in there . Fractals fans are 25mm deep so what size screw do I need , as I don't have spare case screws and I'm not sure the fan will come with screws or not.
Also ill probably need an extra cable to get the fan connector to the controller , it's a long way from the fan , can I use a PWM extender even if the fan isn't PWM?
Thanks.
Reactions: LeVzi
