Case Fan Help
Shadeslayer110
490
You generally have two means to control fans:
1. Motherboard
2. Fan Controller
The Motherboard offers more fine tuning and "hands free" control . Fan Controllers are mostly hand (knobs) control. If using CHA / OPT headers on the MoBo, you can't use that in conjunction with a PCB or cable splitter feed from PSU as 12v from PSU will override the voltage signal from the Motherboard.
-ModMyToys sells PCBs which take a variable DC voltage signal and will send it to multiple 3 pin fans
-Swiftech sells a PCB that takes a PWM signal from the CPU headers and will send it to multiple 4 pin PWM fans. This does work with the 12v PSU signal as it's PWM not voltage controlling the speed.
-Phanteks make a combination PCB that is unique in...
You plug the MOLEX into the PSU to power the controller. Then you plug in each 4 or 3 pin fan into the 4 connectors you can see. They are controlled by the molex power. If you connect fans to this controller, then you can't plug into motherboard. You can either have motherboard OR controller. If motherboard, they are software controlled and if controller, then it is manually controlled by you.
P.S Unfortunately you can't use molex fans with this.
Where do you plug the 4 3 pin fans? Where is the connector?
Its the four connectors as you see in the picture.
Where are those 4 connectors connected to? The fans?
No its like this.
Case fan controller = molex + 4 x black female connectors (like in picture )
Molex --> PSU
Each Fan --> one of the female connectors
Ok, thanks. it is like that, however, the fans still do not work when I turn it on. Why is that? Two of the small connectors where already in the fan control
1. Motherboard
2. Fan Controller
-Phanteks make a combination PCB that is unique in that takes either a PWM or DC voltage signal to control 3 pin DC fans. If you use the 12v PSU feed, then you must use a CPU PWM header or again the 12 signal over rides the speed control.
In short .... other than the Phanteks unit
A DC controller can work automatically with variable voltage control via the MoBo only if not using the 12v connector. This leaves you with either "knob / switch" control or some sort of control integral to the controller itself, negating the functionality any type of MoBo connection.
