So, I want to buy some case fans and replace the ones that came in my computer case. I currently have an el Macho grande rt sitting atop my turbo boosted core i5-9600k in a phanteks eclipse p400s. There is this ones setting button on my case that sets the case fans to the same speed or % as my cpu cooler. My case has 6 spots for fans but I don’t want any more than 4, I might buy 2 to replace the case fans that came with my case, and get a couple more later. Also, I think it might help cool down my graphics card, it’s set to auto fan speed and it gets a little noisy during gaming (Rx 580 gaming x 8gb). I like silence, silence is a good thing, I have a smart fan mode in my motherboard BIOS (MSI Z390A-PRO) that the hotter my cpu gets, the fastest my fan goes, and as a result my case fans too. When I’m not gaming my case fans are the majority of the noise, so if I replace those with quieter, more effective versions, then they will be quieter and more effective, making my cpu cooler which would make my fans turn slower and they would be even quieter. This might be too much information. The point it: My case holds 6 120mm fans, I have Nactua NF-S12A FLX Picked our. But I’m also told that my case could also have 140mm fans. My cpu cooler is pretty big, and the end of it is an inch or two away from one of my output case fans. If they are bigger then will they be too close? Also, do I need to put a case fan there if the cpu cooler is blowing directly out of the case, so I could just put 2 of the case fans in the other 2 spots? (Side question, if I take out my cpu cooler to replace/remove a case fan, do I need to reapply thermal paste?) And is there a better case fan option for my situation? Just some general advice. Sorry this is long, I had a similar question about my cpu cooler and you guys were really helpful and suggested a better one than one I had picked out, so thanks!
