• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question Case Fan Help
Exterminator1
12
Hi everyone, So I recently ordered a new case ( Phanteks Evolv Shift Air) Should get it here in a couple hours.
So from the looks of the case you get one Phantek 140mm fan with the case
which leaves me with 2 open spots (i think according to the manual. I don't plan to use a Radiator with this case (yet).
I have a couple fans laying around which are
1x 14omm COOLER MASTER A12025-12CB-3BN-F1
1x 120mm COOLER MASTER A12025-12CB-3BN-F1
2x 120mm Silverstone SST-FN124 (Slim Fans)
1x 120mm Scythe Slip Stream Slim SY1212SL12M (Slim Fan).
Not sure which ones i should use. I'm sorta worried about Air Flow/Cooling. At the moment i don't plan to do any Overclocking.
Also The Fan Layout on the case seems a bit confusing so i'm not sure where i should have my intake fans and out take fans. from the looks of the PDF it looks like u should only have the one 140mm phantek fan as a outake and the 2 other's one on the very bottom and bottom chamber as intakes. Any insight would be appreciated! Thank You!.
