Case Fan Help
kuichi
34
Hi I'm having trouble with one of my case fans. The case is NZXT source 210 elite. The case fan cable is too short to reach one of the headers on my motherboard (ASRock H77M). I have a molex cable but I'm not sure how it works. The case fan cable has a 3pin power, a male and female molex connector. The molex has a male connector and 2 4pin power connector. I tried plugging the male molex into the female and plugging the 4pin into my motherboard but that isn't working. Can someone help explain how molex works? Also could it be that the fan is broken? Thanks.
The rest of my build:
CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($149.99 @ Microcenter)
Motherboard: ASRock H77M Micro ATX LGA1155 Motherboard ($69.99 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($41.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ NCIX US)
Video Card: Sapphire Radeon HD 7850 1GB Video Card ($169.98 @ Newegg)
Case: NZXT Source 210 Elite (White) ATX Mid Tower Case ($39.99 @ Amazon)
Power Supply: SeaSonic 520W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($71.99 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($24.98 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ Outlet PC)
Keyboard: Gigabyte GK-KM5200 Wired Standard Keyboard w/Optical Mouse ($12.99 @ Amazon)
Total: $756.87
(Generated by PCPartPicker 2012-12-20 22:10 EST-0500)
You just plug in the Molex. With it hooked to a molex it doesn't need to be hooked to the motherboard.
Is your fan PWM? If so, you might look into cable extenders. I honestly don't know if they make them, but I don't believe you can power a PWM fan from molex and still run it off the MOBO.
JMer806
515
kuichi
34
I think I was using a wrong cable. So I just connect the molex and connect it to the psu?
JMer806
515
No, definitely not. I assume you're referring to the ones on the PSU molex cable? No, just leave them, you don't want to damage the cables in any way. Same thing with any unused cables coming off of your fan.
