Currently building up a PC and just getting everything set up, as a first time build.
For reference sake, I'm running with the CiT neptune case
https://www.cclonline.com/product/105682/CP-626-BLUE/Cases/CiT-Neptune-Gaming-Case/CAS0790/
It's position is under a desk with plenty of legroom at its side where I can situate 2 fans onto the window (I presume).
As it stands, I have a front fan and rear fan (120mm) and running the stock Intel CPU cooler (Which obviously faces the window with ventilation holes). As im aiming for good ventilation over noise, I'm considering the inclusion of a side window fan, but my problem is understanding if it should be intake or exhaust?
It being intake, i presume it would create a cross-breeze across the board and push components to a higher unnecessary heat?
With it being switched to exhaust, I expect that there won't be enough air going through the case to the components to keep heat to a minimum?
I should also note that I MIGHT be buying the reference RX 480, So fan orientation will most likely be all over the place, so some expert advice will be worth investing in.
Y'know, before I set my rig on fire
