Hey guys, so i finished building my new gaming rig with a Coolermaster HAF 912 case and i want to add an air filter. I have a 200mm fan infront and i've been searching around the net for a 200m dust filter and the ones i found are expensive for what they are, plastic with metal mesh, or too thick to fit (modright brand).
So, i was thinking of cutting a square 200mm aluminum wire mesh that i could pick up at home depot and just screwing it infront of my fans, would this work and give optimal air flow while catching dust? If you guys have a better suggestion please share!
Also, i'm planning on installing a slim dvd drive and placing a 140mm (bigger or smaller.. havent sized yet) coolermaster fan infront of my haf 912 case (where all the drives are supposed to be, above my main 200mm fan). So maybe i can just cut a big sheet of aluminum mesh and zip tie it to the back of my front case?
