Case Fan Not Working
Delilah_1
Commendable
Aug 23, 2016
65
Recently i bought a case fan for my PC because while i game for 2-3 it heats up.
I installed it into a empty slot and connected the 4 pin connector to 1 of my 2 motherboard "slots".
After i connected it i turned on my PC and checked speedfan.
It only said that my CPU and GPU fans are spinning and when i looked into the case the fan wasnt spinning.
Any ideas why?
All your answers are in the MoBo manual
http://asrock.pc.cdn.bitgravity.com/Manual/H81M-DG4.pdf
Page 4
1 x CPU Fan Connector (4-pin)
1 x Chassis Fan Connector (4-pin)
1 x Power Fan Connector (3-pin)
CPU Quiet Fan (Auto adjust chassis fan speed by CPU temperature)
CPU/Chassis Fan multi-speed control
Page 10 is image of MoBo for Legend below
Page 12
15 Chassis Fan Connector (CHA_FAN1)
21. CPU Fan Connector (CPU_FAN1)
Page 27 - How to connect fans (CPU and Chassis / System Fan)
System / Chassis Fan (4-pin CHA_FAN1) (see p.9, 10, 11, No. 15)
CPU Fan Connector (4-pin CPU_FAN1) (see p.9, 10, 11, No. 21)
Page 68 - BIOS control for fans (CPU and Chassis / System Fan)
CPU Fan 1 Setting - Select a fan mode for CPU...
Very hard to give a recommendation w/o identifying the MoBo, fan and what specific header it was connected to.
Speedfan is a utility that serves when the MoBo utility / BIOS control is unavailable ... a quite rare occurrence in this era. Check your BIOS / MoBo Manual is the only generic advice I can give w/o knowing components in question
Same as JackNaylorPE, it is hard to tell the issue without knowing the MoBo. If you weren't too set on using third party software that tracks the fan usage, you could always plug the fan directly into the PSU through the cords that have the numerous 4-pin molex connectors on them. If the fan uses a different pin orientation, you can always buy adapters to convert the 4-pin to maybe 3-pin fan connectors.
MOBO Model: H81M-DG4
My PSU: http://xfxforce.com/en-us/products/ts-series-bronze-full-wired/ts-series-550w-psu-p1-550s-gren (not sure if it has the conncetor)
Page 4
Page 12
CPU Fan 1 Setting - Select a fan mode for CPU Fans 1, or choose Customize to set 5 CPU temperatures and assign a respective fan speed for each temperature.
Chassis Fan 1 Setting - Select a fan mode for Chassis Fan 1, or choose Customize to set 5 CPU temperatures and assign a respective fan speed for each temperature
Asrock tuning utility which includes fan control can be downloaded (US) here:
http://asrock.pc.cdn.bitgravity.com/Utility/A-Tuning/A-Tuning(v2.0.269).zip
All downloads here ... utility is called "ASRock A-Tuning utility ver:2.0.269"
http://asrock.com/mb/Intel/H81M-DG4/?cat=Download&os=Win1064
The above are all manual page numbers NOT PDF page numbers.
AsRock Utility for fan control and other features is described here
http://www.tomshardware.com/reviews/z77-express-ivy-bridge-benchmark,3254-4.html
Still don't know what fan is tho.
Thanks alot for helping me and sorry for wasting your time.
Good thing i kept the manual.
Anyway thanks alot man :)
MERGED QUESTION
Question from Delilah_1 : "PSU Cable List"
See answer here:
http://www.tomshardware.com/answers/id-3190761/case-fan-working.html#18619280
Pics are in your manual.
BTW, please limit form posts to one post per topic.
