Case Fan Placement for Phanteks P300
Oct 18, 2018
I plan to put;
2 x 140mm at front,
1 x 140mm at top,
1 x 120mm at rear.
Any suggestion? Is it okay for airflow? Thanks. (140mm fans are from Noctua which is 1200-300rpm, 120mm fan is a stock fan that comes with the case and rpm can not be managed.)
That will be a good setup. It will provide plenty of airflow, and the slight positive pressure will help prevent dust buildup. Make the fronts your intakes and the top and back your exhaust.
how is your cpu and gpu temperature now? im planning to do the same setup. thank you
