My current PC was purchased as a gift for me around 6 months ago. The case has one rear exhaust fan that up until recently was working fine. I've been monitoring the PC with HWInfo since I got it and the fan has always run at 3k rpm. It has a 3 pin connector and no way for me to adjust the settings in the BIOS, which means the fan should always be running at full speed.
About a week ago I noticed loud vibrations coming from the computer so I pulled up HWInfo and saw the case fan rpms fluctuating heavily. Sporadic vibration continued and the fan speed jumped around between 2k rpm all the way down to 100 rpm. I turned the computer off for a few hours and upon start up it was running at its normal 3k rpm again for a few days until the same problem occurred again.
I've opened the case up and thoroughly cleaned the inside paying close attention to the fan, making sure to remove all the dust and double checking that it was connected properly. Still having the same issue however. Sometimes it will run days without issue, other times only a couple hours.
Has anyone ever encountered a similar issue?
