Hi,
I have the Fractal Design Define R4 Series Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811352024&cm_re=fractal_design_define_r4-_-11-352-024-_-Product
I only have the fans that came with it. One in the front, one in the back, 120mm. My cousin is jumping down my throat about buying fans with higher RPMs for sufficient cooling because it has that 'capability to cool' under extreme circumstances in gaming.
I don't know how many case fans to buy and how airflow should go in my case. Can someone help me? I was going to buy the Silent R2 Series (the one's that came with my case) as additional cooling. Thank you.
