Case Fan Screws are to Small
chimpbagel
121
Hello,
I bought a Aerocool Strike-X One today, and a Cooler Master Standard 120 MM Fan.
The 4 Screws I got are simply just to small.
Sorry for my bad grammar,
Thanks
As I don't think cooler master will waste shipping on sending you some scews, try some rubber screws:
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=60_325&products_id=36173&zenid=a2d222b444b209d71b1078d2dcc216b8
they are hard to install but reduce vibration and fit a variety of screw sizes. Please note there are also different size rubber screws aside for the one above, so if you think it's too small just get one size bigger with the rubber screws. They can squeeze quite a bit.
