Case Fan Setup Help!
Alan_95
Building my first computer, and bought a raidmax cobra z case which comes with 2 fans pre-installed both 120mm. One front bottom intake fan, I'm not sure the power but I do know it's the same as the exhaust fan in the top back. I also purchased 2 140mm fans planning to put one at the top as exhaust and one at the bottom as intake. The bottom fan holder does not fit a 140 though! I read it wrong so I currently have 2 exhaust top fans. Both cooler master and both 1000 R.P.M and 60.9 air flow. Where should I position those fans? Should I do one 140 intake and one 140 exhaust on the top? or should I leave those two and try and get another 120 for the intake at the bottom of my case? There is no option for side fans as well!
My setup:
Raid max cobra z
Intel i5 4690k
asrock z97 extreme 4
zotac gtx 960
Cx600 corsair psu
1 tb WD
1 SSD seagate 250gb
evo 212 Cpu cooler
Thanks in advance!
More than likely, the extra fans will prove to be unnecessary and just add more noise. But since you have them... use them as top exhaust. Heat rises.
