Case fan size?
killerloader
26
I'm trying to find a Case Fan for my "N81 Mid Tower" Computer Case.
On the wall of the case, there is a circular grate which looks like a fan should go there, as it can be unscrewed, I measured diagonally from one screw to another and it was about 148mm
One screw to another vertically or horizontally is about 104mm.
None of these are actual fan sizes, i think 140mm is closest. - So what should i choose?
Yeah sorry, i didn't know if it was measured diagonally.
Makes sense to be 120mm, considering there would be some extra room to each side of the screw.
Thanks invalid!
@dottorrent
If they are measured non-diagonally, then 140mm is far too much - Considering i measured about 104 that way, still, thanks for the help! :)
