Question Case fan spinning at constant rate (~1400rpm) regardless of BIOS fan curve and settings.
Jun 24, 2022
I recently installed a new AIO cooler in my MSI tower and since it came with fans so I repurposed the old ones which are the same brand (MSI). Everything is solid and responding properly and temps are fine except that one set of 2 fans that are plugged into the system 6 fan header do not seem to be responding to pwm changes. When in the BIOS and editing the fan curve, even if I disable smart fan and send it to zero they continue to spin around 1400rpm. My first guess was something wasn't seated right but everything seems to be plugged in properly. I don't know what the next step in testing would be before it's determined something is bad with the fans themselves.
Specs:
MSI Z590 pro wifi
i7-11700k
rtx 3080
16Gb Ballistix DDR4 ram
MSI Aegeus Case
MSI RGB 120mm fans unknown model
Paperdoc
Polypheme
Ambassador
Any chance those two fans are actually plugged into the PUMP_FAN header, not SYS_FAN6? the PUMP_FAN header normally will run its "fan" at full speed all the time since that is what most AIO pumps are designed to do.
