I have an ASUS z170 pro gaming MB in a corsair spec 1 case. The front fan that came with the case just stopped working, although the LED lights that are part of the fan light up. Okay... opened case and installed new fan. Same result. The cpu fan works fine and a top exhaust fan (same corsair fan as well) works as well...I tried moving the cable connect to another fan 4pin on mb. no joy. I have made no changes to mb bios since last update about 90 days ago. The fan worked after upgrade. ASUS says send board for repair under warranty. That is the last option in my opinion. ANY thoughts??
