Case Fan upgrades!! help me choose
flamehead269
341
I am looking to replace my stock case fans with some high powered ones (preferably LED and if so red, green, or blue) my case is listed below:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352023
I am looking to replace all fans in my case, and add some if able to, help me choose and check to see if I can add some 😀 Specs are in my sign, and my budget for each fan is $15-20.. Thanks Tom
Edit: I am putting in a h100i inside, so I dont think I can mount 2 more on the top because of the h100i.
So Im looking to replace the case fans..
