I've installed a case fan just behind the CPU heatsink for exhaust, in such a way that the heatsink's fan pushes air toward the exhaust fan. Its RPM slows down and fastens again in a fraction of seconds. Its not a fan problem as I tested with other fans too. This position is causing it.
My CPU fan is an ANTEC A30.
The CPU fan RPM is not as high to make the fan waver.
The case fan is from the ANT ESPORTS superflow kit.
What could be causing this?
