Hi
I'm putting together my first computer and I think I've settle on an A64 w/ the MSI K8T Neo-FIS2R mobo. I plan on running a 9800pro but I dont think I'll be getting into any overclocking. So right now I'm looking around for a decent case with good airflow. But I've come across some contradicting stuff..
One guy was saying on another forum that you need more intake fans than outake, and on yet another forum some said the exact opposite! (more outake than intake). they both said something about air pressure (positive and negative?) So if someone could clear that up for me, which is right, or if it should be 1:1 or whatever, that would be great.
Cases I'm looking are the Chenbro Xpider, Artec 868 (It's actually the RaidMax 868, but under the Artec name?), and also this Diablo Tek Demon case that I can only find on tigerdirect.ca(http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=541440&Tab=1&NoMapp=0)
the Diablo case seems to have a good amount of fans but I cant find any reviews or anything, anywhere!
I want one of those three because they seem to have decent features, good reviews (except Diablo?), and also because I have access to them either via free shipping or a local store
I'm going to get the Antec True430W power supply. If you have any opinions/experience on those cases (especially the Diablo one) that would be great and appreciated.
Last question.. sorry bout all this but I think it's better I put it all in one thread than spam the boards
This is probably pretty newb of me, but I was wondering about heatsinks or ways to cool the A64 cpu? I'm not sure if the CPU comes with it's own cooling, or if I need to get one seperately since i'm building from scratch? the A64 is NOT oem if that makes a difference? remember i dont plan on overclocking so i wont need to deal with extra heat.
thanks
I'm going to get the Antec True430W power supply. If you have any opinions/experience on those cases (especially the Diablo one) that would be great and appreciated.Last question.. sorry bout all this but I think it's better I put it all in one thread than spam the boards
This is probably pretty newb of me, but I was wondering about heatsinks or ways to cool the A64 cpu? I'm not sure if the CPU comes with it's own cooling, or if I need to get one seperately since i'm building from scratch? the A64 is NOT oem if that makes a difference? remember i dont plan on overclocking so i wont need to deal with extra heat.thanks
