Case Fans and Motherboard Help and suggestions
Prophet171
81
I have a question about my Antec nine hundred mid size case and ASUS Z97-PRO GAMER LGA 1150 i am about to order. The MoBo has a CPU fan header, CPU OPT fan header, and 3 chassis fan headers. The case has four fans. 2 front 120 mm, 1 top 200 mm and 1 read 120mm or maybe it is 140mm. Anyways How is the best way to go about connecting them all and being able to have full speed control over them through the mobo and full features i could get like temp and what not?
I would use a fan splitter and put the two 120mm fans on the same header, and then a separate header for each of the other two. Optionally, you could buy a fan controller that goes in your drive bay if you have an open drive bay. Fan controller would most likely be better. NZXT also makes fan controllers that can just go in your case instead of the drive bay.
Fan controller in a drive bay so i can control it from the front of the case? Okay a fan splitter for the front two fans, i think would be better because i will be able to control them from the motherboard
