[SOLVED] Case fans at 0 RPM
Jul 1, 2018
41
Hi
I have 1 cpu fan and 6 case fans that plugged in into smart device that came with Nzxt h700i
But when i go to msi bios and go to control fans the cpu fan noctua nh-d15s showing 200ish rpm while the other 6 fans showing 0 rpm
Is this normal ?
If it's a controller it'll likely shut off the fans to lower noise when temperatures are low. If you believe they should be spinning, look inside your PC and check if they're spinning or not.
