[SOLVED] case fans in front of aio ones?
Simple answer is, No.
You should follow through with what's been said in your other thread, here;
You can also look into the watercooling sticky in my sig, specifically in the Closed Loop section towards the end.
Since when did lack of RGB suddenly make a pc 'ugly'?
The nzxt stock fans are considerably better quality and better output for the rad than Anything montech will use for a case fan.
On top of which, the X3 fans are fixed, they use molex plugs, so are not controlled, cannot be controlled and the only reason they are halfway quiet at that speed is because they are quite miserable output.
Best thing you could do is get rid of them, they are semi-useless.
