Case fans/lights turn on for second, but whole computer won't turn on.
Aaronm9
30
Some lights flash for a second but computer won't turn on. I know that the case lights and fans turn on but the cpu cooler doesn't nor does the gpu in that second. i just moved from my dorm and set it up back home and this is when it wouldn't turn on. it seemed to be in a secure place during travel, so i'm not sure what to think.
Board- MSI Z97 Gaming 5
GPU- GTX 780
CPU - i5 4690k
Storage 1TB Seagate and 250gb samsung SSD
RAM-Corsair vengance 8gb total
Power Supply- Corsair CX750M
GPU- GTX 780
CPU - i5 4690k
despite me building this I'm still not confident in my ability to perform this. Not really sure what to unplug/disconnect, mainly what cords to take out.
Nothing happened, lights flicked as I hit the on switch on the back off computer.
Not sure but I'll look it up. I doubt its oversized due me using it for the last 4 years? I could be wrong though.
If it uses a 120mm fan or greater, it's oversized. Most coolers are these days.
unplugged the fan and still the same
The CPU cooler can act as a lever when you are transporting the computer. If you're in a car, and hit a bump, the CPU cooler can have enough momentum to break either the traces of the motherboard or the solder points of some ICs.
Normally, you would remove the CPU cooler before transporting the computer in a vehicle.
Nope, just an hour and a half drive with no bumps I can remember,
upright, and seemed to be in a solid area. Not a lot of moving could've been done,
I do not have access to another machine sadly
