Hello!
I'm looking forward to building my very own PC but I have some questions. First of all my case will be Cooler Master N200 ( this one ) which is a mini-tower and I'm wondering what fans to choose and how to mount them.
This case has room for 5 fans so 3 of them should be intake (front and side) and 2 exhaust (top and rear), that's for positive pressure I guess. I noticed that this case also has a dust filter pre-installed at the top fan and if the fan I'll mount here will be exhaust it really doesn't make any sense to have a dust filter so... do you think I'll be able to take this filter out and mount it on the side fan (which will be intake) ?
Anyway, I don't know what fans to choose and that's because there are lots of bearing I can't recognise. I know that sleeve bearing works with some kind of grease so I shouldn't mount them horinzontally 'cause the grease will somehow leak and it will cause some problems I guess. So, which brands are the best ? I guess Noctua are one of the best but they're also quite expensive for me. I've read that Cougar, Nanoxia, Corsair and be quiet! are also good.
Are these one good for horizontal and vertical mounting ? Their bearing is hyper spin and I really don't know what this is . But how about these one from Nanoxia ? Good for horizontal and vertical ?
Anyway, could you recommend me some fans for horizontal and vertical mounting for intake and exhaust within 30 $ ? By the way, I'm from Romania so I'm not sure I'll find here everything you have in the US but I'll do my best.
