Question Case fans on AIO
simmyx
345
14
4,695
Went for the kraken x53..
I should be able to use two of my corsair rgb fans instead of the stock right?
They are case fans, so I'll have to monitor the temps . If no good then I'll use the stock ones .
Ryzen 5 3600, no overclocking.
I have two 140mm fans at the front and one 120mm at the back in a meshify c case
besides cooling the CPU, you still want enough cool air being drawn into the case to keep your GPU and\or other components cool.
plus enough of the air warmed by the GPU\motherboard\RAM\etc still exhausted out.
so if you're removing case fans to use on the radiator, you should replace them with something else.
simmyx
345
14
4,695
I'll keep 2x140mms at the front, and 1x120mm at the back. That should be fine ?
