[SOLVED] Case Fans operating too loudly
Feb 15, 2019
I own 4 corsair ml120 pro fans which are meant to be very quiet, and my system also doesn't require that intense of cooling. However the fans in my case always operate very loudly on startup, idling or playing games. Could there be a reason for them to be operating so loudly?
Thank you
The Asus Prime Z370-A motherboard I used to build my current main PC had the fans set to max in the BIOS/UEFI fan profile when I first built the PC. Barty may be on to something...
Every once in a while, I might be 🤣
I've never seen an ASUS board default to 100% fan speed personally but, if @JozuaK hasn't manually configured it (in the BIOS or software) and yet it's running at ~2400rpm constantly, it's likely a default in the BIOS.
What motherboard are they connected to?
If you do not have the PWM (or DC) ability to control speeds, chances are they're just running at 100% rpm. While fans can be optimized for silence, any 120mm fan running at 100% speed will produce a decent amount of noise (some more than others, of course)
The motherbord I am using is the Asus tuf gaming plus II and it does have pwm fan ports
Upon further inspection of the four fans two are running at 2500 rpm while the other 2 always stay at around 500rpm.
