Case Fans Optimisation
justice507
41
Two possibilities:
3 x 120intake fans in front, 1 x 120 exhaust at the back and 1 x 120 at the top
OR
3 x120 intake fans in front, 1 x 120 exhaust at the back
Which one is the better choice here? I prefer cooler temperatures for both CPU and GPU.
Case: Fractal Meshify C (it has 2x120 opening at the top)
CPU: AMD RYZEN 2700X
GPU: Nvidia 1060 GTX 6GB
3 in front is good, I'd suggest 1 on top and 1 on back. The more air you can't get out of the case and replace with fresh air is always better. After running your system for a while you might turn off one front and maybe the top-temps will tell
