Case Fans Phanteks Eclipse P400S Help
BrycePC
Commendable
Apr 19, 2016
48
So I am thinking about getting Phanteks new P400S case however I have no idea how to set up the case fans.
I am not going to be implementing any radiators quite yet so I have all the fan spots available within the case.
Any help would be greatly appreciated. Thank you for your time.
You want if possible 2 intake fans in the bottom front of the case and an exhaust fan in the back near the top of the case.
It looks like the case comes stock with one front intake and one rear exhaust, that might be sufficient at least initially depending on what parts you plan to put in the case.
What size fans would you recommend? The P400 has room for 2x140mm or 3x120mm fans in the front and 1x120mm fan mount on the back.
