For about a week now, my desktop has been behaving oddly. My case fans unpredictably start and stop working. Sometimes I turn the computer on and they don't spin up. They start spinning if I manually spin them (usually via a quick blast of compressed air aimed at the fan), but not as fast as they should be (I can tell this just by looking at them) and my computer quickly overheats. If I run SpeedFan to see what's going on, it reports them turning at impossible speeds, anywhere between 20,000rpm and 250,000rpm. Obviously, there's no way a fan in my case is spinning at 250,000rpm. So, the fan speed is reporting incorrectly as well.
Other times, I turn the computer on and everything is fine. Fans spin up on their own and SpeedFan reports normal looking numbers for a case fan. The weird thing is they work in unison. They either all spin or none of them spin. I've never observed only some working.
Interestingly enough, one of the fans on my video card died at the same time. Won't spin no matter what, even when the case fans are working. It's a video card with 2 fans on it. One works all the time, one is totally dead. As luck would have it, I had just ordered a new video card so I'm not too concerned with figuring out what's wrong with the video card because I'm replacing it anyway. (I got a new 4k monitor and as it turns out, R9 270s cannot handle gaming in 4k resolutions, so I needed a new one.)
But the 4K monitor is the final thing I need to mention: Everything stopped working after I got a new monitor. I don't see any way a monitor could fry my system fans, but it sure seems like it did. Also odd is the computer rebooted for some reason while I was plugging the monitor into the computer. I didn't do it or anything. Again, I don't see how a monitor could do this, but it sure seems like the monitor caused it. All these problems started happening as soon as I plugged the monitor into the video card.
Does anyone have any idea what's going on or how to fix this?
My computer's specifications as well:
Case: Corsair Graphite 230T (With stock fans on it. Two in the front, one in the back)
Motherboard: Asus M5A97 LE R2.0
PSU: Corsair TX750
CPU: AMD FX-4130 3.8ghz (the CPU fan has not had any issues)
Memory: Corsair Vengeance 8GB DDR3 1600 (1 stick)
GPU: EVGA GEForce 1070 GTX
Monitor: Asus PB287Q 28"
The machine itself was built in 2014, and the GPU is the only part that wasn't bought in 2014. In fact, I just installed the 1070 a few hours ago. And yes, I really like Asus and Corsair.
So, does anyone have any idea what the heck is happening here? I thought the fans had died at first, but now that seems less likely. Any idea on how to fix this?
And now, I'm going to go turn my machine on and off a bunch of times and hope the fans start working so I can play Rocket League.
PSU: Corsair TX750
