So as I was using my beautiful new build last night, my case fans stopped working. No rgb or spin at all.
I'm using a DIYPC vanguard v8, which has an aurus sync header for the fans.
My motherboard is a asrock phantom gaming 4, which uses polychrome. I'm aware the two aren't compatible but I'm not using polychrome to control the case fans.
My cpu fan, also not controlled by polychrome, works fine and is plugged in on the same line to the psu.
Everything boots fine and windows runs. My USB and power on the case work, just not the fans.
I have tried other fans on the same spot from the psu and they worked fine.
In Bios, my 4 fans show up as well as my case fan header. However, the header shows up as cpu fan 2/ w_pump switch, and the 4 fans show up as Cha fan/ wpump switch. They show no reading for speed.
