Case fans; straight to PSU or Mobo
mikeny
1,476
Was curious, what the concensus on case fan connection? I have the CM HAF 932 Full tower. Should I directly connect the fans to the PSU or use the motherboards connectors? I have the Asus Gen 3 Pro board (P8Z68).
It has CPU, CHasis and power fan connectors (4pin CPU-FAN/CPU_fan_OPT, 4pin CHA_FAN1, 3pin CHA_Fan2, 3PIN POWR_FAN1-2.
I also have the Corsair HX850w PSU modular continuous power.
[fixed]have the CM HAF 932 Full tower. Should I directly connect the fans to the PSU or use the motherboards connectors? I have the Asus Gen 3 Pro board (P8Z68). [/fixed]
Use the PSU, so the mobo have less excuses to fail on u.
Use for the mobo only cooler related fans.
For the case fans, u can use aftermarket controller.
