Hi All
I've recently completed my first build, which was intended as a quiet rig (Quiet Base 802, i5-12400, TUF RTX 3080, Seasonic PX-850, a Mag B660 Tomahawk, and a Noctua NH-D15S) .
I wanted to use some sort of fan controller to set up custom curves.
I'm trying the software (Fan Control) https://github.com/rem0o/fancontrol.releases recommended here:
View: https://www.youtube.com/watch?v=uDPKVKBMQU8
When I set up Fan Control, it didn't seem to recognise my case fans, even though the case fan controller hub connects to the MOBO at the SYS_Fan3: View: https://imgur.com/a/BraDh24
Any advice on how to proceed here? Can I just take the 3 case fans and plug them individually to the MOBO, or is there another solution?
Regards
Daniel
As a side-note: the "control manually" option isn't working for any of the fans (CPU, GPU, and case) so I don't know if there's something I've missed more generally. I was going to try get the system fans connected before looking for a solution to the next problem.
Regards
Daniel
