case fans wires snapped, possible to repair?
AliRidha
253
He guys so I was opening my PC to install an audio chip when the PC side door fell from my hand and snapped the case fan wires. The copper inside is exposed. Is it possible to repair?
Yea, strip both ends of whats left of the wires coming from the fan and do the same for the power connection wires that broke, then simply connect the wires to the matching colors. Just make sure you electrical tape all the wires and keep them seperated or you'll short something out.
Its probably not even worth it they way you described it. It may just be easier to look or purchase and new fan and install it. I guess you could try, but it would be extremley difficult to fix it because it broke at the fan.
