Question Case for Arctic Liquid Freezer II 360 or 420
Tyson14
4
Hello guys,
I am building a new PC and looking for a Case where I could mount the AiO top. (As far as I know, top mount is better than front)
Can you recommend a case for circa 110 Euros, with a window, place for 1 HDD + at least 1 SSD, and very good airflow?
I, therefore, do not need any soundproofed properties.
Despite that, does there even exist a good case for a 360 or 420 Arctic Liquid Freezer which fulfills the criteria above?
It should cool a Ryzen 5900x. My graphics card is a GTX1080 GLH Edition and my mainboard and ram, so keep in mind the measurements.
I would appreciate any recommendations.
If there is no case that fits the criteria above I think I will go with a BeQuiet500DX and a AS500
geofelt
You are asking for trouble using a high end aio cooler when a good air cooler will do the job.
Noctua has an extensive cpu/cooler suitability chart.
Here is the one for the 5900x:
https://ncc.noctua.at/cpus/model/AMD-Ryzen-9-5900X-1045
NH-D15 is the best,
but you may note that even a NH-U14s will do the job.
Look for a case with at least 160-165mm cooler height and at least two 140mm front intakes
How about this cm H500 with two 200mm front intakes?
https://www.amazon.co.uk/Cooler-Master-MasterCase-H500-High/dp/B083FLCWT2/ref=sr_1_1?dchild=1&keywords=cm+h500&qid=1633912036&qsid=259-4407798-1776231&sr=8-1&sres=B083FLCWT2,B079JVTPJK,B07TC76671,B00RORBQNW,B07KGSJRC3,B07SGWLD2C,B01MSE3M3W,B0839Y7933,B07QM91RJQ,B07SB43M56,B07S8ZMD2T,B075DMYVBV,B083LW1XYK,B07DRVHBWK,B07FL1D5RV,B07PW4DMQY&srpt=COMPUTER_CHASSIS
