Case for first build
MrKillChill
Commendable
Sep 16, 2016
71
This is my build that im doing in christmas/new year:http://uk.pcpartpicker.com/list/w32Jnn
I want a better case at around the same price range,the reason i picked this case is that all the others that i find like the nzxt 340 or something just look like boxes.
What i want;
Good airflow
Good looks
Side window
Ok cable management
And prefferably 2+ fans
Nothing wrong with the spec 02. Buy a case that you love; you will be looking at it for a long time.
One suggestion, buy a Cryorig H7 cooler instead. The case specs show that the hyper212 is a smidgeon too tall. The H7 is only 145mm tall.
Thank you , i didnt really like the look of that case + it had a white interior and also cost more than the spec 02 , i think ill stick with the spec 02, and im pretty sure it will fit the 212x because its shorter (by 1mm) than the evo and ive seen multiple videos with the evo inside the case thank you
