Case for gtx 1080 ti
jerrys0706
5
Hey guys
After years of gaming on a laptop, I finally decided to get myself a computer(mostly for gaming, netsurfing, youtubing and some video editing/rendering)
Here are the specs I'm working with:
i7-7700k
asus rog gtx 1080 ti
msi z270 gaming pro
corsair rm750x
corsair ddr4 8gbx2
sandisk 1tb ssd
ASUS VG248QE monitor
thermalright le grand macho rt cooler
I still can't decide between a mid tower and a full tower case. Which one should I go for?
And also are there any improvements that can be made?
Thanks in advance!!
Thanks for the reply
I checked them out but do they actually fit the grand macho rt cooler?
Looking it up your height should be exactly 159 mm on your cooler. So in theory (I say in theory because I have never owned one) they should fit all the cases linked, the only one that would draw some concern is the NZXT S340 as it supports 161 mm cpu cooler height. So 2mm might be a bit snug, if that’s a case you are looking into ide do some googling to make sure. (P.S I didn’t mean to vote down on your answer I’m on my phone)
